MPLAB error
Discussion in 'Programmer's Corner' started by knwnuts, Mar 12, 2009.
  1. knwnuts
    Mar 4, 2009
    Hi...im using MPLAB IDE(lite) to program pic. But i have this error which i have no idea where to check. Anyone can help?
    The error is as below:
    Error [1347] ; 0. can't find 0x90 words (0x90 withtotal) for psect "text76" in segment "CODE" (largest unused contiguous range 0x31)
  2. n9352527
    Oct 14, 2005
    1,198
    Post your code.
  3. knwnuts
    Mar 4, 2009
    the code is quite long...and i've put bank1 to the arrays..the errors are lesser now..the errors:
    Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" -C "C:\Documents and Settings\admin\Desktop\ZD\main.c" --chip=16F627A -P --opt=default -q -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
    Warning [348] C:\Documents and Settings\admin\Desktop\ZD\main.c; 36.23 auto variable "delay_addr" should not be qualified
    Warning [348] C:\Documents and Settings\admin\Desktop\ZD\main.c; 37.23 auto variable "delay_cmd1" should not be qualified
    Warning [348] C:\Documents and Settings\admin\Desktop\ZD\main.c; 38.23 auto variable "delay_cmd2" should not be qualified
    Warning [348] C:\Documents and Settings\admin\Desktop\ZD\main.c; 39.23 auto variable "delay_cmd3" should not be qualified
    Warning [348] C:\Documents and Settings\admin\Desktop\ZD\main.c; 40.23 auto variable "delay_cmd4" should not be qualified
    Executing: "C:\Program Files\HI-TECH Software\PICC\LITE\9.60\bin\picl.exe" -oillum_fw.cof -millum_fw.map --runtime=default,-clear,-init,-keep,-osccal,-download,-ramtest,-resetbits main.obj "C:\Documents and Settings\admin\Desktop\ZD\illum_fw.hex" --chip=16F627A -P --opt=default -q -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
    Error [491] ; . can't find 0x114 words for psect "rbss_0" in segment "BANK0"
    Error [491] ; . can't find 0x14 words for psect "rdata_0" in segment "BANK0"
    Error [593] ; . can't find 0x3F6 words (0x3f6 withtotal) for psect "text10" in segment "CODE"
    not so sure if putting bank1 is a gd idea.
    Code ( (Unknown Language)):
    1. #include <pic.h>
    2. #include "delay_.h"
    3.
    4. char led_c=2;
    5. long counter = 0;
    6. char stepPointer = 0;
    7. bit flagA;
    8. bit flagB;
    9. bit flagP;
    10. bit flagM;
    11. char a;
    12. char resol = 0xFE;
    13. int i;
    14. #include "step_table.h"
    15. #define  button_A RA4
    16. #define  button_B RA1
    17. #define  button_P RA3
    18. #define  button_M RA2
    19. #define  G1_LED1  RB6
    20. #define  G1_LED2  RB2
    21. #define  G1_LED3  RB4
    22. #define  G2_LED1  RB1
    23. #define  G2_LED2  RB5
    24. #define  transmitted RB7
    25. #include "initialize.h"
    26. #include "buttonM.h"
    27. #include "buttonP.h"
    28. #include "buttonA.h"
    29. #include "buttonB.h"
    30.
    31. void main(void)
    32. {
    33.  bank1 int delay_addr[]= {9000,4500,560,560,560,1690,560,1690,560,560,560,560,560,560,560,560,560,1690,560,1690,2250,560,560,560,1690,560,560,560,1690,560,1690,560,560}; //0x61d6
    34.  bank1 int delay_cmd1[]= {560,560,1690, 560,1690,560, 560,560,1690, 560,560,1690, 560,1690,560, 560,560,1690, 560,560,1690, 560,560,1690}; //0x48
    35.  bank1 int delay_cmd2[]= {560,560,1690, 560,1690,560, 560,1690,560, 560,1690,560, 560,1690,560, 560,560,560,  560,560,560, 560,560,560}; //0x78
    36.  bank1 int delay_cmd3[]= {560,560,1690, 560,1690,560, 560,560,1690, 560,1690,560, 560,1690,560, 560,560,560,  560,560,560, 560,560,560}; //0x58
    37.  bank1 int delay_cmd4[]= {560,1690,560, 560,560,1690, 560,1690,560, 560,560,1690, 560,560,1690, 560,560,1690, 560,560,1690, 560,560,1690}; //0xA0
    38.  __CONFIG(0x3E01);
    39.  initialize();
    40.  for (i=0; i<2; i++)
    41.  {
    42.   DelayUs(delay_addr[i]);
    43.  }
    44.  for(i=2; i<18 ;i++)
    45.  {
    46.   G1_LED1=1;
    47.   DelayUs(delay_addr[i*2-1]);
    48.   G1_LED1=0;
    49.   DelayUs(delay_addr[i*2]);
    50.  }
    51.   if (button_A==1)
    52.  {
    53.   for(i=0; i<8 ;i++)
    54.   {
    55.    G1_LED1=1;
    56.    DelayUs(delay_cmd1[i*3]);
    57.    G1_LED1=0;
    58.    DelayUs(delay_cmd1[i*3+1]);
    59.   }
    60.   for(i=0; i<8 ;i++)
    61.   {
    62.    G1_LED1=1;
    63.    DelayUs(delay_cmd1[i*3]);
    64.    G1_LED1=0;
    65.    DelayUs(delay_cmd1[i*3+2]);
    66.   }
    67.  }
    68.  if (button_B==1)
    69.  {
    70.   for(i=0; i<8 ;i++)
    71.   {
    72.    G1_LED1=1;
    73.    DelayUs(delay_cmd2[i*3]);
    74.    G1_LED1=0;
    75.    DelayUs(delay_cmd2[i*3+1]);
    76.   }
    77.   for(i=0; i<8 ;i++)
    78.   {
    79.    G1_LED1=1;
    80.    G1_LED1=0;
    81.    DelayUs(delay_cmd2[i*3+2]);
    82.   }
    83.  }
    84.  if (button_M==1)
    85.  {
    86.   for(i=0; i<8 ;i++)
    87.   {
    88.    G1_LED1=1;
    89.    DelayUs(delay_cmd3[i*3]);
    90.    G1_LED1=0;
    91.    DelayUs(delay_cmd3[i*3+1]);
    92.   }
    93.    DelayUs(delay_cmd2[i*3]);
    94.   for(i=0; i<8 ;i++)
    95.   {
    96.    G1_LED1=1;
    97.    DelayUs(delay_cmd3[i*3]);
    98.    G1_LED1=0;
    99.    DelayUs(delay_cmd3[i*3+2]);
    100.   }
    101.  }
    102.  if (button_P==1)
    103.  {
    104.   for(i=0; i<8 ;i++)
    105.   {
    106.    G1_LED1=1;
    107.    DelayUs(delay_cmd4[i*3]);
    108.    G1_LED1=0;
    109.    DelayUs(delay_cmd4[i*3+1]);
    110.   }
    111.   for(i=0; i<8 ;i++)
    112.   {
    113.    G1_LED1=1;
    114.    DelayUs(delay_cmd4[i*3]);
    115.    G1_LED1=0;
    116.    DelayUs(delay_cmd4[i*3+2]);
    117.   }
    118.  }
    119.  while(1)
    120.  {
    121.   for(counter=0; counter<AUTOOFFTIME; counter++)
    122.   {
    123.    DelayMs(5);
    124.    if(AUTOOFF==0) counter=0;
    125.    if (button_A == 0)
    126.    {
    127.     buttonA();
    128.     counter = 0;
    129.    }
    130.    else if (button_B == 0)
    131.    {
    132.     buttonB();
    133.     counter = 0;
    134.    }
    135.
    136.    else if (button_P == 0)
    137.    {
    138.     buttonP();
    139.     counter = 0;
    140.    }
    141.
    142.    else if (button_M == 0)
    143.    {
    144.     buttonM();
    145.     counter = 0;
    146.    }
    147.
    148.    else
    149.    {
    150.     asm("nop");
    151.    }
    152.   }
    153.
    154.  a = PORTB;
    155.  PORTB =1;
    156.  CCP1CON = 0;
    157.  while (1)
    158.  {
    159.   DelayMs (5);
    160.   if ((PORTA & 30) != 30)
    161.   {
    162.     DelayMs (10);
    163.     CCP1CON = 0x1F;
    164.     asm("nop");
    165.     PORTB = a;
    166.     asm("nop");
    167.     counter = 0;
    168.     DelayMs (30);
    169.     break;
    170.   }
    171.  }
    172.   }
    173. }
    174. [/i]
  4. knwnuts
    Mar 4, 2009
    Actually i made another program...but still the same kind of errors..
    Error [1347] ; 0. can't find 0x8C words (0x8c withtotal) for psect "text77" in segment "CODE" (largest unused contiguous range 0x31)
    Error [1347] ; 0. can't find 0x6A words (0x6a withtotal) for psect "text75" in segment "CODE" (largest unused contiguous range 0x31)
    Error [1347] ; 0. can't find 0x17 words (0x17 withtotal) for psect "text81" in segment "CODE" (largest unused contiguous range 0x0)
    1.
    1.
    2. #include <pic.h>
    3. #include "delay_.h"
    4. #include "ir_.h"
    5.
    6. char led_c=2;
    7. long counter= 0;
    8. char stepPointer = 0;
    9. bit flagA;
    10. bit flagB;
    11. bit flagP;
    12. bit flagM;
    13. char a;
    14. char resol = 0xFE;
    15.
    16. #include "step_table.h"
    17.
    18. #define  button_A RA4
    19. #define  button_B RA1
    20. #define  button_P RA3
    21. #define  button_M RA2
    22. #define  G1_LED1  RB6
    23. #define  G1_LED2  RB2
    24. #define  G1_LED3  RB4
    25. #define  G2_LED1  RB1
    26. #define  G2_LED2  RB5
    27. #define  transmitted RB7
    28. #include "initialize.h"
    29. #include "buttonM.h"
    30. #include "buttonP.h"
    31. #include "buttonA.h"
    32. #include "buttonB.h"
    33. void main(void)
    34. {
    35.  __CONFIG(0x3E01);
    36.  initialize();
    37.  while(1)
    38.  {
    39.
    40.
    41.   for(counter=0; counter<AUTOOFFTIME; counter++)    //an infinite loop for continuous reading of interrupts.
    42.   {
    43.    DelayMs(5);
    44.
    45.    if(AUTOOFF==0) counter=0;
    46.    if (button_A == 0) //if button A press down
    47.    {
    48.     Send_IR_Command(0b0110000111010110,0b01001000);
    49.     buttonA();
    50.     counter = 0;
    51.    }
    52.    else if (button_B == 0) //if button B press down
    53.    {
    54.     Send_IR_Command(0b0110000111010110,0b01111000);
    55.     buttonB();
    56.     counter = 0;
    57.    }
    58.
    59.    else if (button_P == 0) //if button '+' press down
    60.    {
    61.     Send_IR_Command(0b0110000111010110,0b01011000);
    62.     buttonP();
    63.     counter = 0;
    64.    }
    65.
    66.    else if (button_M == 0) //if button '-' press down
    67.    {
    68.     Send_IR_Command(0b0110000111010110,0b10100000);
    69.     buttonM();
    70.     counter = 0;
    71.    }
    72.
    73.    else
    74.    {
    75.     asm("nop");
    76.    }
    77.   }
    78.   a = PORTB;
    79.
    80.   PORTB =1;
    81.   CCP1CON = 0;
    82.   while (1)
    83.
    84.   {
    85.    DelayMs (5);
    86.    if ((PORTA & 30) != 30)
    87.    {
    88.     DelayMs (10);
    89.     CCP1CON = 0x1F;
    90.     asm("nop");
    91.     PORTB = a;
    92.     asm("nop");
    93.     counter = 0;
    94.     DelayMs (30);
    95.     break;
    96.    }
    97.   }
    98.  }
    99. }
    100.
  5. n9352527
    Oct 14, 2005
    1,198
    Usually the error means there is not enough memory location to place some variables. I see that you include other files, which are not posted above. It might be arrays in those other files are too large.
  6. hatteet
    Mar 23, 2009
    hello everybody......
    how are you??
    i need a necessery help ....
    i need the wiper motor mplab code so that i can control it using the 16f877a pic..
    thank u for helping me...
    i need it in the nearest time plz....
    thank u again
    this is my e-mail for contact me
    hatteet@yahoo.com
