MPLAB Error with Assembly
ELECTRONERD
Joined May 26, 2009
1,147
This is extremely frustrating; I freshly installed v8.60 from MPLAB, just as you suggested t06afre, and the build STILL freezes right in the process of presumably "Executing", as it indicates. I don't get any results, it just remains at that point and won't continue. This must be an error with MPLAB itself, otherwise I would get a "BUILD FAILED" from the assembler. I don't know what else to do, I'm almost ready to switch to AVRs.
ELECTRONERD
Joined May 26, 2009
1,147
Well I finally found the problem, which is a huge relief, let me tell you!
Apparently the folder I was storing my assembly projects in was corrupt. After running MPASM.exe alone it gave me a bunch of directory errors because it couldn't locate the file. So, I made a new folder and the build's stopped freezing. Now they are successful!
Those of you who have this problem now know that it is most likely what I described above.
Thanks to everyone who tried your very best to help, I am grateful for your efforts.
