mplab compiler error: 'BORV_27' undeclared here (not in a function)
Discussion in 'Embedded Systems and Microcontrollers' started by somchai, Nov 6, 2012.
  1. somchai
    Oct 27, 2012
    5
    Hai there,
    im an engineering student from malaysia
    i been working on this c programming but now only have one error that i dont know
    For your info, i use Mplab 8.30 + mplabc30_v3_30c_windows compiler software...
    1) Together with this thread are :
    2 Print screen image of error and the source of error....
    Hope anyone from the forum can help me out
  2. spinnaker
    Oct 29, 2009
    5,065
    1,162
    Most people will not open a doc attachment. Do not post docs.
    Post a png file.
    Post the code in between code blocks. I think there is a sticky that tells you how to do this.
    somchai likes this.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Check the header file that references the part you are using. Sometimes the names are a bit off.
    somchai likes this.
  4. somchai
    Oct 27, 2012
    5
    HI THERE,
    tHANX FOR THE COMMENT TO IMPROVE MY THREAD
    I BEEN WORKING ON THIS C PROGRAMMING BUT NOW ONLY HAVE ONE ERROR LEFT!!!!!!!!!!
    FOR YOUR INFO, I USE Mplab v8.88 + mplabc30_v3_30c_windows compiler software...
    Debug build of project `C:\Users\somchai\Desktop\Testing\Test1.mcp' started.
    Language tool versions: pic30-as.exe v3.31, pic30-gcc.exe v3.31, pic30-ld.exe v3.31, pic30-ar.exe v3.31
    Preprocessor symbol `__DEBUG' is defined.
    Wed Nov 07 03:13:50 2012
    Clean: Deleting intermediary and output files.
    Clean: Deleted file "C:\Users\somchai\Desktop\Testing\dijkstra.o".
    Clean: Deleted file "C:\Users\somchai\Desktop\Testing\encoder.o".
    Clean: Deleted file "C:\Users\somchai\Desktop\Testing\Test1.mcs".
    Clean: Done.
    Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4011 -x c -c "dijkstra.c" -o"dijkstra.o" -D__DEBUG -g -Wall
    Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4011 -x c -c "encoder.c" -o"encoder.o" -D__DEBUG -g -Wall
    Executing: "C:\Program Files (x86)\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4011 -x c -c "msr.c" -o"MSR.o" -D__DEBUG -g -Wall
    msr.c:13: error: 'BORV_27' undeclared here (not in a function)
    Halting build on first failure as requested.
    Debug build of project `C:\Users\somchai\Desktop\Testing\Test1.mcp' failed.
    Wed Nov 07 03:13:53 2012
    BUILD FAILED
  5. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    I have merged the threads, as you do not have to start a thread for the same question.
    Bertus
  6. spinnaker
    Oct 29, 2009
    5,065
    1,162
    Check your source for a line that says:
    BORV_27
    Check the spelling.
    Make sure it is either spelled right or you have the header included or it is pre declared in your source.
