Moving west Away from Sun Rise
Discussion in 'Math' started by loosewire, Nov 21, 2009.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    How fast would you have to move west to keep ahead of sunrise
    in east. Assuming you had a clear pathway. With earth rotating
    toward the sun.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Depends on the latitude. John
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    At the equator, it's close to 24,900 miles around the planet. To go that far in 24 hours means you have to move at 1,037.5 MPH. Faster at altitude, as the circumference of your path increases. In geosynchronous orbit, it's 24,900 MPH.
  4. someonesdad
    Jul 7, 2009
    1,585
    141
    If the circumference of the earth at the equator is C, then the circumference of the earth at latitude θ (i.e., the circle created by a cut by a plane parallel to a plane containing the equator) is C cos \theta. Divide that by the period of rotation (say, the sidereal day) and you have the linear velocity you desired. Add in complexities as desired (e.g., nonspherical earth, topography, etc.).
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    This speed varies based on latitude and altitude.
    At 45 degrees North latitude, the required speed is 731 mph or 1176 km/h.
    At 30 degrees North, the speed increases to 896 mph or 1442 km/h.
    At the Equator, you would need to be going 1035 mph or 1666 km/h
    This is assuming ground level. At altitude, where those speeds can be reached, the difference isn't huge, but you'd need to go a bit faster.
