Hello all,
I have one of these
http://www.omega.co.uk/ppt/pptsc.asp?ref=CDTX300
This is within a big adaptable box and I need to move the 4 x trimmers so the user can insert a small screwdriver into the side of the big adaptable box and turn them
I have taken the unit apart (see below pics)
The length I need to extend these is around 300mm
According to the spec sheet
http://www.bourns.com/pdfs/3296.pdf
one is 200 ohms
and the other three are 50K ohms
Due to these working on resistance if I were to get 4 x 300mm lengths of 3 core screened cable, desolder them and move them do you think it is possible? In theory they are easy to mount on the inside of the big adaptable box as all I would need to do is drill 4 x holes into it and possibly glue them in place so the user just pushes in a screwdriver and turns them.......
I have one of these
one is 200 ohms
