movie( )
Discussion in 'Programmer's Corner' started by onqun, Feb 25, 2009.
  1. onqun
    Feb 17, 2009
    15
    Hello guys,
    x=mmreader('myvideo.mov')
    movie(x)
    when I write these commands I get these results.
    Video Parameters: 24.08 frames per second, RGB24 960x540.
    151 total video frames available.
    ??? Error using ==> movie
    Invalid movie structure: wrong number of fields"
    My question is how can make it work the movie command since it only works with 8-bit image frames. :confused::confused:
  2. veritas
    Feb 7, 2008
    167
    What language and/or library are you using. It's not clear from your code snippet.
  3. onqun
    Feb 17, 2009
    15
    Thank you for replying. I am new to the matlab. I need to use the getframe command. I am unable t use that because i can not use the movie command because of the file format, I guess:) . I am using matlab:)
