@SgtWookie:
Sorry for my confusion earlier, I had pictured the circuit you have designed was going to be just for the marquees, and that there was going to be another similar circuit for the other LEDs (so my shopping list has double the requirement). Should I get the extra parts in case the other LEDs don't look right?
@Craig
Is this OK for the switch?
http://www.rapidonline.com/Electronic-Components/Switches/Slide-Switches/Standard-slide-switch/30267
Or you can choose your own (but assuming you are going to put it in a box it needs to fit from the inside so that you don't have to desolder and then resolder the wires).
Also would you like an external knob to vary the speed in the final soldered version or would you just set it to the correct speed and leave it?
@Craig
