What is the easiest way too mount and connect a TO-204 package? Is there a PCB/heat sink package on the market to make this simple? Also, could i just mount it to a heat sink with the pins sticking up, away from the heat sink?
The device I'm trying to use is a 2n3055. The driving circuit is mounted on a buss board with wire leads for the 2n3055.
Also, does anyone know the difference between the TO-204 package and the TO-3 package? I have parts from three difference manufacturers that appear to be physically the same, but are listed as different packages.
