mounting speaker and mic
Discussion in 'General Electronics Chat' started by bug13, Aug 19, 2014.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    How can I mount a speaker and mic on a plane without getting feedback? The plane(speaker and mic) needs to be mounted on the ceiling.
    The speaker need to be heard reasonably well, and the mic needs to be able to pick up voice.
  2. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    Is the speaker re-broadcasting what the microphone is picking up?
  3. bug13
    Feb 13, 2012
    1,213
    38
    It's going to be a two way communication. The speaker is connected to the the mic on the other end with similar configuration. The speaker is suppose to broadcast whatever from the other end.
    The goal is enable people in different room can speak to each other. But I believe I am having feedback problem.
  4. Lestraveled
    May 19, 2014
    1,957
    1,217
    Try changing the phase of the speaker. If this does not work then the fixes get more expensive.
    Graphic equalizer - Notch out the frequency of the predominant feedback frequency.
    Feedback killer - A delay generator for audio use. This device inserts very small amounts of delay to change the phase of the feedback.
    Check music stores for both of these devices.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    You can also use an echo cancellation mic. A signal from the speaker is fed back out of phase into the microphone preamp circuit thereby cancelling the sound picked up from the speaker.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    That's why they make "press-to-talk, release-to-listen" switches...;)
  7. bug13
    Feb 13, 2012
    1,213
    38
    What do you mean by changing the phase of the speaker? Like switching the connection of the two wires to the speaker?
  8. bug13
    Feb 13, 2012
    1,213
    38
    This might be a good solution in other case, but not in this one. :D
  9. bug13
    Feb 13, 2012
    1,213
    38
    Never know this, I think I need to google this, thanks!
  10. Lestraveled
    May 19, 2014
    1,957
    1,217
    Yes, just swap the speaker wires. Sometimes it works.
  11. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    The pickup pattern of the mic makes a difference, too...an omnidirectional capsule is going to "hear" the speaker lot more than one with a more unidirectional pickup pattern.
  12. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Because of sound reflections in each room that will inevitably lead to feedback unless a) each room is made anechoic or b) both mics are muted, made highly directional or screened, to prevent pickup from general room noise. A signal feeding the speaker in a given room could perhaps be used to mute the mic in that room?
  13. bug13
    Feb 13, 2012
    1,213
    38
    That might be a good solution for my application, I will talk to other people and see what they think.
  14. bug13
    Feb 13, 2012
    1,213
    38
