I am trying to come up with ways to mount / connect LCD displays like the one pictured in my projects.
What I have been doing is to make a small daughter board with a 2 row 16 and single row 16 pin header.
This takes extra work making the LCD PCB and takes up a bit extra room.
One thought I had was to just connect the LCD header right to my main PCB but the problem with that is that the LCD faces the front panel so I would have mounting screws for the PCB on my front panel. Plus there is the issue of lining two boards up for mounting as opposed to tow separate boards.
Any tips on tackling this problem?
