Motorola GM300 PTT Mic to Kenwood TM-261A Transceiver
Discussion in 'Wireless & RF Design' started by radiohead, May 25, 2011.
  1. radiohead
    Thread Starter Active Member
    May 28, 2009
    I have a Kenwood TM-261A transceiver and needed a hand mike. I found a Motorola GM300 microphone, but when it was plugged in, it did not work. So I re-wired it. Here's how...
    Remove the three captive screws on the back of the microphone and pull the two halves apart.
    De-solder the small black wire from the ground plate on the back side of the microphone
    Remove the CCA from the housing, and remove the rubber boot over the microphone. (no screws holding it in)
    From the CCA, de-solder the blue, black, red and green wires.
    On the CCA, the holes are labeled BL, BLK, RED, GRN
    Solder the blue wire to the BLK pad
    Solder the black wire to the RED pad
    Solder the red wire to the GRN pad
    Solder the green wire directly to the electret microphone positive and test the unit.
    Re-assemble the mic assembly and you are done.
