motorola 68hc711
Discussion in 'General Electronics Chat' started by krusty, Mar 10, 2013.
Thread Status:
Not open for further replies.
  1. krusty
    Mar 10, 2013
    i am looking for some software and a quick and easy interface to read and write these babys.
    old technology i know but i need to fix some cars with this.
    thanks in advance
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Good luck getting an answer here. The administrators of this site have decided not to host any automotive discussions due to safety and liability concerns. Just makes things a little less dangerous. They have provided a list of other sites where your topic would be better suited. Considering yours also involves programming microprocessors, I'd personally recommend Electro-Tech-Online.com.
    Here's the thread with the list of other forums: http://forum.allaboutcircuits.com/showthread.php?t=54400
    I'm sure a moderator will contact you shortly in response to this thread, just to let you know.
    I wish you all the best!
    Regards,
    Matt
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    The actual dealing with the cars won't be involved Op only wants to know how to program these chips.
    So the answer is the same no matter if used for cars or whatever.
    If they are automotive controllers then they are not designed for interference except by service personnel.
    Means it is unlikely in this case programmer modules are sold openly.
    http://www.dataman.com/dataman-s4-programming-the-68hc711
    DATAMAN programmers are not cheap, they are intend for professional usage.
    I can not see any information about automotive. 68hc11 family.
    Ask on the Freescale forum.
  4. MrChips
    Oct 2, 2009
    12,636
    3,454
    What is the part number on the 68HC711?
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I believe the chip is integrated into the car's computer, which makes it part of the car itself. Therefore, I doubt the mods will allow the discussion, though I could very well be wrong.
  6. takao21203
    Apr 28, 2012
    3,578
    463
    But it is not an automotive modification as such.
    Anyway, I see some chance this thread will be closed.
    Making changes to the firmware may render the vehicle no longer permitted for public roads.
    OP would need a servicing license.
  7. krusty
    Mar 10, 2013
    just need to read old engine ecu code and edit to new ecu code in main body control unit.
    then car will start
    only land rover dealers can do this for ££££££££
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That most certainly won't be allowed on the forum. Messing with the ECU programming is very risky. You might turn it into a brick, or worse--turn your car into a deathtrap. You won't find an answer here.
  9. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
