Hi
Referring to SgtWookie's design for Motorcycle Rectifier-Regulator (Post #5) at
http://forum.allaboutcircuits.com/threads/12v-ac-motorcycle-regulator.39419/
1) I would like to request SgtWookie to please explain the use of the inductor L1. That circuit simulates the exactly same without the inductor.
2) I simplified it as per attached. I got perfect regulated voltage 14.4V; the mosfet remained super cool however, only D3 got hot. Doubting the condition of D3, I replaced with a fresh one but same result. I would like to have some valuable comments, why it is getting hot and what should be done to control heat dissipation.
Thanks in advance.
Thanks in advance.
