MrSoftware
- Joined Oct 29, 2013
- 2,202
On the MotoGP bikes they use a load cell in-line with the shifter linkage. On the upshifts they kill the ignition, on the downshifts the ECU blips the throttle (all fly by wire). I posted a picture below from a google image search.
For the noise, you might try resistor spark plugs. They are sometimes used to reduce interference, maybe it will help (assuming your software solution doesn't do the trick).
https://www.ngksparkplugs.com/about-ngk/faqs/spark-plug-faqs/when-should-i-use-a-resistor-spark-plug
