Hi all,
Been thinking about this for a while and confused after reading lots of threads on here.
I want to add a small solar panel or two the the back of my motorbike to trickle charge the battery when she's parked up at work.
I assume this is possible, but unsure what I need to consider or use.
I'm not after charging the battery as such, just maintaining it a little. Its a big old lump and if the battery not in decent charge, sometimes there isn't enought juice to turn her over. I can't use a charger in garage as have no power there, so thinking of adding a panel there to.
I'm looking to add a small panel or two to my rear seat cowl and have them on a quick connect type attachment so can be used when out and about and then when back in garage, disconect and connect to a panel mounted on garage door, so effectively swapping the panels so gets trickled charged wherever she is.
Is there a minimum panel needed for the cowl to make it worth it, or will any do?
Would I need a charge controler or would a diode be enough to stop the cowl panel causing any discharge? Also, is there any concern with overcharging and having it plugged in whilst running the bike (ie whilst riding).
Regards the garage door panel, would a 20w panel with controler be safe for leaving plugged in, ie same overcharge and discharge preventions.
Sorry for all the A's, I don't understand solar and this is my first foray so any help would be great.
Kind regards, Upex
Kind regards, Upex
