Motorbike charger
Discussion in 'General Electronics Chat' started by sej1234, Apr 2, 2010.
  1. sej1234
    Apr 2, 2010
    :confused:hi sir, i m new user and i m not electronic stundent but now i m repairing mobile and some knowldge of electronic I want to make homemade charger for mobile which can charge mobile battary from my motorbike.
    i want to make 12v dc to 6v dc supply for mobile battary 3.7v dc.so pl. give me deatile of parts list and circuit diagram and adv. Thank
  2. Dumble 4
    Apr 2, 2010
    HI ! buddy actually this type of do not a easy because you have to know about basic thing trhen after home made charger is not fully safe because they have chances to short circuit . I have request to you you just check near shop those one who repair electronic item .
    All the best !
  3. retched
    Dec 5, 2009
    5,201
    313
    Do you want to build a battery charger, or do you want to provide power to a cell phone that contains its own charging circuit?
  4. sej1234
    Apr 2, 2010
    hi sir actully in bike 12dc battary. i want to charge my cell phone batter via mobile and mobile have charging ic and other componant it means i want to charge mobile from my motorbike thats all.and thank u for replay e.i dont want to buy buy from market.
  5. retched
    Dec 5, 2009
    5,201
    313
    Understood. Do you have the charger IC that you want to use? Or do you want to start from scratch?
  6. sej1234
    Apr 2, 2010
    i want to use 7805 ic to regular supply to mobile form 12v dc battary i want to only part list and circuit diagram befor i made charger with 7805ic ,100uf cap,100nf cap,and 15ohm ressiter it supply is ok but mobile charge sign only diplay but not charge battary how can use perfect part in this circuit.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See the attached schematic.
    U1, R3, R4 can be replaced by a 7805 regulator. You should use a heat sink on the regulator.
    You probably did not have enough filtering on the regulator when you tried it before.
    If you wish to increase the output voltage of the 7805 regulator, you can add resistance between the GND terminal and the motorbike's ground. 500 Ohms will increase the output approximately 1 volt.
    Notice that there is an 0.33uF capacitor next to the input of the regulator, and an 0.1uF capacitor next to the output of the regulator. These capacitors should be as close as possible to the regulator, or it may oscillate all by itself at high frequency.
