motor
Discussion in 'General Electronics Chat' started by joni, Dec 2, 2009.
Thread Status:
Not open for further replies.
  1. joni
    Oct 4, 2009
    39
    I want to build a module for electrical motor scooter that can rise in slop
    I search after sketches and shops that sales these modules
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Joni,
    It is not necessary to use the custom fonts; it makes it harder to read your post.
    Do you have this electrical motor scooter already, and it's controller module is broken?
    Or is this something new that you want to build?
    You will need to supply a lot of details, such as:
    What voltage does this scooter use?
    What current does the motor use?
    What is the control input for speed?
  3. joni
    Oct 4, 2009
    39
    I didn't buy an electrical motor or energy supply for this project
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you will need to start out with some kind of plan.
    Like, how much weight do you expect the scooter to move, including itself?
    Is the area where you live fairly flat, or are their shallow grades, or steep hills?
  5. Bernard
    Aug 7, 2008
    4,242
    417
    For some ideas on motors- try All Electronics.
  6. joni
    Oct 4, 2009
    39
    Thanks, but before I buy module for the motor
    I need to understand it and find information about this
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Joni,
    You wrote in the first post:
    "I want to build a module for electrical motor scooter that can rise in slop"
    I can only guess that English is not your first language.
    I should have also guessed that you already have an electrical motor scooter that does not go up slopes very well.
    I think that what you want to do, is to build a controller for an electrical motor scooter that you already have, that will make it go up hills better?
    Is that what you are trying to say?
Thread Status:
