Motor with alternating direction
Discussion in 'The Projects Forum' started by mcm513, Jan 18, 2012.
  1. mcm513
    Jan 18, 2012
    Hi, I have a similar (perhaps simpler) problem. I need to cycle my motor such that it rotates clockwise for a certain time interval (let's say 5 seconds) and then reverses and rotates counterclockwise for 5 seconds. I want this cycle to repeat continuously, and I was wondering what the simplest approach would be? Do I just use an interval timer and relay? I do not need the motor to pause before it reverses, as was the case above. Any help would be greatly appreciated. Thank you!
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    I don't know if it's the simplest solution, but a simple solution would be an NE555 astable multivibrator with a 5 second pulse time connected to a DPDT relay wired to reverse the polarity on the motor. That is assuming the motor is low voltage DC. Post the voltage and current requirement of the motor.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
