motor speed control
3dracer01
Joined May 10, 2010
Hi im new to forums and new to electronics
im making a record player and i have a problem with controling the speed of the motor its a 6V running off a 1.5v power source
how can i make the motor spin slower but can still use the same voltage
i have other things that needs at least 1.5v
mik3
Joined Feb 4, 2008
4,843
If it is a low power motor use a resistor in series with it. However, if it is a high power motor use PWM to control the average voltage across the motor and thus its speed.
3dracer01
Joined May 10, 2010
im not sure if its low power or high power
it spins really fast on full power
would a potentiometer or some kind of hand control be used
i want to be able to control it by hand too
im soory i didnt say that before:)
SgtWookie
Joined Jul 17, 2007
22,230
Use a belt speed reduction. A small pulley on the motor's shaft and a belt that goes around the record platter.
The motor pulley should have a high spot in the middle; aka convex. That will keep a flat belt tracking in the middle of the pulley.
You will need to use controls such as a phase lock loop in order to keep the platter rotation speed steady. If you don't, you will have very noticeable "wow" and/or "flutter".
A heavy, well-balanced platter on really good bearings will help to minimize the wow/flutter. A flywheel on the motor will also help a great deal to keep the speed constant.
