I need a point in the right direction with the following question:
Q: The rotor of a d.c. motor had an original diameter of 30 cm and an air gap under the poles of 2mm. During refurbishment the rotor diameter was accidentally reground and was then undersized by 0.5mm. Estime by how much the field MMF would have to be increased to restore normal performance. How might the extra MMF be provided?
All I can think of to solve the question is ohms law (magnetic). The reluctance of the air gap I can solve but not the flux?
