Motor Power supply design
Discussion in 'General Electronics Chat' started by GoswamiG, Jun 7, 2016.
  1. GoswamiG
    Aug 26, 2015
    5
    Dear all,
    I am working on my new project . This project haveone ATMEGA 328 P and motors . I was trying to run the motor & controller on the same supply but controller get reset. it is a well known problem but my project cannot afford 2 power sources So I need to design anew power supply
    can anyone suggest a relevant tutorial or design I can follow for supply design.
    Rgds
    SG
  2. Kermit2
    Feb 5, 2010
    3,845
    963
    Keep motor ground and circuit ground separate except where they come together at battery.
    Monitor voltage when motor starts. Powersupply must be able to source this current without voltage sag. If voltage drops when motor starts. Redesign using higher current capable supply
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Isolate the mcu's rail from the motor's rail. It can be done via a resistor + capacitor, or a diode + capacitor, or a regulator.... all depends on what's available to you.
  4. GoswamiG
    Aug 26, 2015
    5
    thank you for your reply,
    let me add my circuit details. please find attachment I think the SMPS used should not create the problem as it is very stable. (expecting so)
    fo I need to design a new supply so what are points should I consider for designing such power supply ?? ????2??
    @Kermit2 I will check the voltage drop tomorrow I will check
    thank Rgds
