Hi ,
My question may seem basic but is really hard for me to understand, maybe it is not as simple as it appears ? I built an oscillating digital circuit in school. Do not remember too much but it just "flashed "on and off. Considered an A/C signal for most purposes. My issue now is I have a rotating motor and it is 100% D/C fan from a vehicle. I turned it into a generator and measure 1 volt rotating it manually. ( increases voltage and I as speed increases) as far as I got so far. What I do not understand is how it can produce a D/C and not varying A/C emf? I have taken many apart and know the components but what makes a/c motors so different from d/c motors. For instance an A/C motor I experimented with did not have permanent magnets and generates zip , zero emf when spun. Not much use for motors if I do not know how to power them. Thanks for info.
Note: I am using a simple multimeter for measurements -no oscilloscope available, if I connect and it "reads" d/c then I am on the correct range, or try the a/c switch.
