hey everyone, i need help to build a circuit that activate a motor to run forward until it hit a sensor than after a couple second will reverse back. you can say it's like a lifting ordeal. and is control by PLC
Your PLC (do you have a link?) will need two inputs and two outputs. The inputs will detect the (2?) limits. The outputs will determine forward/reverse/brake/coast for the motor through a solid state or relay H-bridge. The PLC should do the timing.
