Motor or Servo?
Discussion in 'The Projects Forum' started by kapakra, Sep 29, 2013.
  1. kapakra
    Sep 14, 2013
    Hello
    This is my first post, so be nice!
    Im building a replacement for a valve on a radiator, with bluetooth and the like.
    Im not sure the best way to go for the actual act of opening and closing the valve, my thinking is that the valve will have a cap that when tightened pushes the pin down and closes the valve.
    So i started to research the best kind of motor to use, and im just lost! I need it to be able to turn CW and CCW on command, so my first thought was servos, but i think torque might be a problem.
    Anyone done something similar in the past and could advise?
    Any thoughts, or a better way to move the pin would be great.
    Thanks.
  2. killivolt
    Jan 10, 2010
    432
    351
    I would go with a servo.
    You could use a worm gear CW/CCW, attach a mount on the cap / spot weld, mount your worm gear assembly atop the mount your actuator ride along the worm gear back and forth which is connected to the lever with a spring, on one side of threaded stock and on the other side of the threaded stock is a roller to roll pressure atop the pull lever, holding it down, once down it resets to middle position, relaxing the spring.
  3. MaxHeadRoom
    Jul 18, 2013
    10,830
    2,500
