Motor Load and No Load Amps
Discussion in 'General Electronics Chat' started by ronscircuit, Jul 2, 2012.
  1. ronscircuit
    Jul 2, 2012
    I have a three phase motor that has a range of 575 Vac to 635 Vac. Is the following correct?
    Under a no-load condition, the motor amps will increase with increasing voltage.
    Under a full-load condition, the motor amps will decrease with increasing voltage.
    Thanks,
    Ron
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    NO, motor current increases with load, so more load = more current.
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    Yes, in general the no-load motor current will increase with voltage due to the magnetizing current, and the (constant) full-load motor current will decrease (assuming the voltage does not go above the rated voltage) since the motor input power remains essentially constant.
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I'll second the yes, within context.
    Decreasing slip, decreases current. At load, slip can be decreased by increasing voltage. This % slip approaches that of no load. Beyond that however, an increase in voltage increases current.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    I'll third. This is my understanding as well.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    The key to the question is that each question is asking about what happens as the voltage is changed while the load, for that question, is kept constant.
