motor feedback
Discussion in 'The Projects Forum' started by engkeat, Feb 27, 2009.
  1. engkeat
    Aug 18, 2008
    i m using an incremental encoder to feedback the speed of a dc motor. i am concern about the frequency of the pulse generate from encoder as i need a find a set point (desired frequency/speed) , the motor is used to lift up a load at a constant speed. during the lifting, torque required is changing, meaning voltage required is changing as i need to control the voltage supplied to motor through the feedback pulses, i m using PIC as the controller. my question is that... can PIC detect the continuous changing pulse from the incremental encoder??? o do i need any converter?
  2. hgmjr
    Jan 28, 2005
    You should consider using pulse-width modulation control of the speed of your motor. You would use your PIC to change the duty-cycle of the control signal to your motor driver based on the input from your encoder.
