hi,
i'm building an rc brushless motor driver using a microcontroller.right now i'm using an L293D to amplify the microcontroller output.i would like to use mosfets for the same purpose,to get more current todrive the motor.the motor is delta connected ,12V and takes 28amps of current with load.please give me the schematic of the circuit,the motor turns at high RPM,hence using a relay would be useless.
thank you.
thank you.
