motor driver
Discussion in 'The Projects Forum' started by sasek, Apr 6, 2010.
  1. sasek
    Jan 3, 2010
    64
    hai all,
    i have a lamp that could operate with AC source, here i want control it damp (intensity of light). my friend suggest to use pwm signal to control AC source of the lamp, so here i need to work with a driver, it ok. but i find driver from internet that all the dirver used DC source n here i need to use AC source. reason i want to use AC source is to save space because the housing of the lamp is so small an it build using concrete......... i hope someone could help me ....................thanks 4 read :)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    sasek likes this.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    Since you seem to lack the experience and skill necessary to work with mains power, I would suggest using a DC powered lamp to try and do some testing on, any mistakes with the mains power can cause serious injury to you and others, and could also possibly cause a fire hazard....
    My.02
    sasek likes this.
  4. sasek
    Jan 3, 2010
    64
    BMorse thanks 4 remind me,
    i have try control the light dimmer using pwm. The result is so weird. Here im using LED to indicate the light. When using pwm the LED will blinking n not archive my objective....is it posible if i using thyristor???? then i supply the gate terminal by using pulse from pwm????
