HI
I been looking for a circuit like Sqt Wookie to use for my project where you can push 1button to made a motor turn in one direction up then push second2 button in the other direct down.
Sqt wooKie:
Can you tell me the relays YOU have in that circuit are they normally closed for RELAY 1 then switch To N.O. or the other way AROUND N.O. THEN N.C.
AND HOW ABOUT RELAY 2
ALSO ARE THESE RELAYS 12VDC INPUT AND 12VDC OUTPUT AT 1A OR 10As
what are the specs for those limit switches.
thanks
Sqt wooKie:
thanks
