Motor dc frequency
Discussion in 'The Projects Forum' started by fourty, Jan 26, 2014.
  1. fourty
    Oct 13, 2013
    13
    hi. plz i want to know if there is a recommended frequency value to control the motor speed .
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    To minimize switching losses (heating) in the PWM transistor(s); as low as possible.
    To minimize acoustic noise (buzzing) in the motor; high enough (likely above hearing range).
    To minimize the size of bypass capacitors; the higher the better.
  3. Alec_t
    Sep 17, 2013
    5,967
    1,135
    I assume from the thread title you are talking about a DC motor.
    Brushed or brushless?
    PWM frequency?
  4. fourty
    Oct 13, 2013
    13
    thanks Mike ML for your help :)..alec_t Im speaking about pwm frequency of a brushled motor controller
  5. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Commercial Manuf. such as the popular A-M-C uses 20Khz PWM freq.
    Max.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Traction motor drivers use low frequencies (couple of hundred Hz) to increase motor performance at very low RPMs.
    You will also see this on devices like cordless hand-drills, to give max torque at very low drilling RPMs.
