Motor Control
Discussion in 'The Projects Forum' started by urb-nurd, Aug 25, 2014.
  1. urb-nurd
    Jul 9, 2014
    269
    Hey guys, so i need to try control a motor.
    I would like to be able to control its speed in continuous rotation.
    However i would also like finer control so that i can make the motor rotate a set value then reverse.
    I was thinking a stepper motor would suffice however that adds some extra bulk to my unit.
    Is it possible to get this sort of control with a h-bridge?
    Rather than a stepper with a little PIC for sequencing
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    For accurate speed or position, some kind of closed loop feedback is needed such as a PID loop unless something like a stepper is used, especially if the load is varying in nature.
    Max.
  3. shortbus
    Sep 30, 2009
    4,095
    1,685
    And depending on the torque/power needed there a some pretty small stepper motors. Most all of the cars made today have stepper motor gauges in the instrument panel. And they are tiny.
  4. urb-nurd
    Jul 9, 2014
    269
    Thanks for that, seems to me like a stepper would be less work for what i need.
    I guess i was just put of by the square nature of the beast haha.
    I like that cylinder
  5. shortbus
    Sep 30, 2009
    4,095
    1,685
    Many older computer printers (inkjet) have small round stepper motors in them, and can be found either cheap or free. :)
  6. ligo.george
    Feb 2, 2013
    19
    You can use L293D to interface DC Motor with PIC Microcontroller.
    If you need to use high current DC Motors, you can make H-Bridge using POWER Transistors..
    You can use PWM (Pulse Width Modulation) to control the speed of DC Motor. By varying the PWM Duty Cycle, you can change the average power delivered to the motor.
    Try the following links :
    Interfacing DC Motor with PIC Microcontroller
    DC Motor Speed Control using PWM with PIC Microcontroller
    If you want to use stepper motor, try the following link.
    Interfacing Stepper Motor with PIC Microcontroller
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Those links do not appear to show feedback to enable fine positioning, which the OP specified in his post.
    Max.
