Motor Control with PIC16F
Discussion in 'Embedded Systems and Microcontrollers' started by nataraj87, Nov 14, 2011.
  1. nataraj87
    Nov 7, 2011
    i want c code for pwm generation to do in PIC16f?
    hi friend,,
    i am going to do fuzzy logic project to control the motor,when obstacle is detected,i am going to use two ultrasonic sensor, if left ultrasonic is detected then it will automatically slow down the left motor when right side motor is going fast. same as if right ultrasonic sensor is detected then it will automatically slow down the right motor when left motor is going fast.so please tell me how to do,what are all components required ,how to do,then i need c code for this project.pls help me to get good output and give me some snapshot to understand easily..
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from
    http://forum.allaboutcircuits.com/showthread.php?t=61707
  3. DumboFixer
    Feb 10, 2009
    219
    34
    You say you are going to do this project, then you ask us to provide you with how to do it, what components you need and the code to do it.
    If we provide you with all that, what are YOU going ot provide ?
    you'll get more help if you have a go yourself then ask about particular problems you have. We, well everybody else really, can then provide guidance on how to solve the problems.
    You will need to provide schematics and code listings.
