motor control circuit bi-directional
Discussion in 'Homework Help' started by rod2133, Jan 2, 2010.
  1. rod2133
    Jan 1, 2010
    Hi everyone I am new to this forum and a novice. All help is appreciated. I want to automatically reverse a reversible 120v AC motor. I would like a delay of 1-2 sec. from off to re-start in the opposite direction. It needs to keep running and reversing until power is removed. Speed control would also be nice. Thanks
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Exactly what type 120vac motor do you want to control? There are many types. What will the motor be driving? A load that will bring it to a stop in less than a second or one that will coast for a while? Many more questions are possible based upon the openness of the original request. As Johnny 5 said, "INPUT, INPUT"
  3. Duane P Wetick
    Apr 23, 2009
    408
    19
    You are going to need a motor with an electronic or mechanical brake. Even a loaded gearmotor will not stop that fast. A reversing starter may be the answer, but the short run, stop and reverse cycling concerns will be difficult to manage.
    Regards, DPW [ Everyone's knowledge is in-complete...Albert Einstein]
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
