I have the a treadmill with a bad motor control board. The 3.0 hp DC Motor does not run, but will run from battery. The board is common, and can be purchased for about $200.00
I'm decent at soldering, and think I could replace a defective resistor, or the part as shown in the photo, though I'm not sure what it is, or where to buy one.
The photos are attached, top, top closeups, bottom, and bottom closeup.
I believe the defective part is likely defective because you can see the blackened marks on the connector, and solder being melted away from connection. Could I be so lucky, that I just need to re-solder the part onto the board, that the part itself is internally OK ?
The part is marked DEC KBJ25J, and has 4 connectors, one of which is black and little or no solder left on it.
Thank you for your help.
Michael
Michael
