Motor Capacitor Question
Discussion in 'General Electronics Chat' started by 127sjl, Aug 14, 2012.
  1. 127sjl
    Aug 14, 2012
    Thank you.
    I have a motor that stopped working. The capacitor was replaced, and all is fine now.
    It's a 50uF 440 VAC
    I replaced with the same.
    The old one reads 42.1uF
    The new one reads 45.3uF
    Will this difference cause the motor to not work?
  2. PackratKing
    Jul 13, 2008
    850
    216
    Not a problem as long as you matched your voltage spec.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Maybe the old capacitor failed because its equivalent series resistance (ESR) became too high but you did not measure it.
    The 9V battery in my smoke detector failed. I measured 8.5V with no load and 3.5V whith a 10k load. It failed because its ESR became too high.
    A brand new 50uF electrolytic capacitor has a wide tolerance of from maybe 25uF to 100uF. If your new capacitor has a low ESR then it will work fine.
  4. #12
    Nov 30, 2010
    16,704
    7,351
    Reads with what? I have found it impossible to get a valid reading on an oil filled motor capacitor with a self powered tester. The only method that works for me is to put the capacitor directly across a 120 VAC or 240 VAC power line and measure the current. Then I can calculate the capacitance under (close to) the conditions it was built for.
