Motor as a rotational sensor?
Discussion in 'General Electronics Chat' started by julijonas, Jun 15, 2006.
  1. julijonas
    Jun 15, 2006
    I would like to ask you how to make a small motor as a rotational speed sensor for microcontroller, i.e. I want to pick up the output from the motor as from a small generator. I need to amplify voltage the motor produces (it produces from 0 to 0,7V) to match microcontroller's readings (from 0 to 5V). Shall I use common-collector or base amplifier? How to protect a microcontroller from damage?
    Thank you!
    Julijonas
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Try looking up shaft encoders. They give outputs compatible with microcontroller inputs, and require very little elaboration to put in your system.
    The ultimate in simplicity is to arrange a small magnet to spin with the shaft, and use a hall-effect sensor to signal when the magnet passes. There is an indication of each shaft rotation, and the output is directly useable by the mc.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    http://www.sensorwiki.org/index.php/Basic_sensor_interfacing_techniques
