Motion sensor
Discussion in 'General Electronics Chat' started by woodguy60, Mar 28, 2015.
  1. woodguy60
    Sep 21, 2011
    20
    Hi I own a cnc woodworking machine the spindle on this machine is water cooled.
    it uses a 1/2 inch water line. In this line i have inserted a plastic paddle fixture that turns when the water
    flows. this is so i will know if the pump is working.
    I need to go one step further with this.
    i would like to add a sensor that will operate an alarm it the paddle stop moving.
    looking for advise how to go about this is there a ready made unit i can purchase or a simple circuit
    i can make.
    thanks Paul
  2. blocco a spirale
    Jun 18, 2008
    1,460
    369
    You could add either an optical or magnetic sensor to the shaft of the paddle so that a steady stream of pulses are produced when the paddle is turning, you then use these pulses to reset a timer. if the rotation stops, so will the reset pulses and the timer will expire, triggering an alarm.
    A 555 monostable circuit is all you need.
    cmartinez likes this.
  3. Brownout
    Jan 10, 2012
    2,375
    998
    Is there an electrical output from the paddle, or is it just something you look at?
  4. cmartinez
    Jan 17, 2007
    3,698
    2,774
    I've done that before... use a 555 circuit configured as a "missing pulse detector", and install a magnet at the paddle, and a hall effect sensor on the outside.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,774
    just noticed your post... shame on my reading skills...
    Anyway... I just wanted to add that there are industrial paddles out there that already deliver the pulses that you need.
  6. woodguy60
    Sep 21, 2011
    20
    its not possible to add anything to the paddle as its inclosed with just an inlet and outlet.
    where can i find one of these industrial paddles. no electrical output from the paddle just something i look at.
    thanks
  7. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    If it has an external shaft that you can attach or glue a miniature button magnet, and then use one of the Honeywell SS400 series of unipolar sensors.
    Max.
  8. cmartinez
    Jan 17, 2007
    3,698
    2,774
    Then you could use an optical sensor... just light up the paddle real well with a white LED to produce a strong contrast of light and shadow.
  9. woodguy60
    Sep 21, 2011
    20
    yes i like the idea of the optical sensor now how do i go from there lots of this is a bit over my head.
    is there some place i can purchase what i need like on ebay? or someplace else. i live in the caribbean
    thanks pau
  10. cmartinez
    Jan 17, 2007
    3,698
    2,774
    How familiar are you with building electronic circuits?
  11. woodguy60
    Sep 21, 2011
    20
    i have some idea of building circuits once its straight forward plus i have testing equipment
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,687
    1,297
    Can you post a couple of photos of your sensor, just to give us a feel for the surfaces and room around it?
    ak
  13. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    If you use optical, they are usually miniature retro-reflective tape style. They are about the size of the end of a pencil eraser.
    I should have a part No around here some where, as I have used them in the past.
    Max.
  14. cmartinez
    Jan 17, 2007
    3,698
    2,774
    And if you do go for optical, you'll need to either shroud from external light that will probably won't let you see the paddle anymore, or use a filtered infrared type of sensor and emitter.
  15. woodguy60
    Sep 21, 2011
    20
    photo i can make a support close to the paddle
      File size:
      950.2 KB
      44
  16. ian field
    Oct 27, 2012
    4,447
    791
    You can buy off the shelf reflective sensors for this type of application, they use IR to reduce the effects of ambient light.
    If even that doesn't beat the ambient light, I'd check out firms like Omron to see if they offer a similar sort of thing, but with pulse modulated IR beam and filtered detector.
  17. Brownout
    Jan 10, 2012
    2,375
    998
    I would consider a lazer diode that shines across the blades, offset from the center so that the beam gets interrupted by the blade as it passes thru the beam.
  18. tracecom
    Apr 16, 2010
    3,878
    1,396
  19. cmartinez
    Jan 17, 2007
    3,698
    2,774
    You know what.... it would be a lot easier if you posted a picture of your wheel paddle
  20. tracecom
    Apr 16, 2010
    3,878
    1,396
    See post 15.
