motion capture for my 3d characters
Discussion in 'General Electronics Chat' started by MegaMan, Jul 15, 2010.
  1. MegaMan
    Sep 25, 2009
    53
    Hello
    I need to buy 10 accelerometers to make a motion capture device and connect it to blender [www.blender.org] , to my characters ..
    or
    by the way , i'm studying Mechatronics Engineering , 3rd year ...
    familiar with Electronics , amplifiers and circuit I & 2 , Logic , ... and stuff
    help choose the right accelerometers !!
    i'm going to use them with an Arduino .
    my skype name is
    dhia.eldeen.mahmoud
    we can talk about 3d or electronics
    thank you ......
  2. retched
    Dec 5, 2009
    5,201
    313
  3. MegaMan
    Sep 25, 2009
    53
  4. Bosparra
    Member
    Feb 17, 2010
    79
  5. BMorse
    Sep 26, 2009
    2,675
    234
    it can be done if you have a good pencil tip soldering iron, and a steady hand.... or you can do what I did with this leadless package, I reflowed the solder using a hot air gun, I applied some solder to each pad, placed the IC on top, heated the board from the bottom with the hot air gun until the solder flowed under the IC...
    B. Morse
  6. MegaMan
    Sep 25, 2009
    53
    but i can see others similar with half the price .
    are there any youtubes of this method ? <searching>
  7. MegaMan
    Sep 25, 2009
    53
    an Engineer told me that it is not possible to catch XYZ from an accelerometer!
    i need an initial conditions and stuff, how far is this precise?
    also told on IRC "free node" that i need magnetometer in conjunction with acce
  8. retched
    Dec 5, 2009
    5,201
    313
    Everything you need is rolled in one IC now.
    You need an accelerometer IC and an analog to digital converter to read the outputs.
    http://www.sparkfun.com/products/252
    A compass IC will give you bearing if thats what you want to find.. Or for more precision, use a GPS module.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    That is only for full awareness, such as "vertical, facing east". Otherwise the only calibration you need to do is get the values when it is perfectly level on the X axis, level on Y axis, and level on Z axis.
    Decide if you want a 1g "zero" or a 0g "zero" in software for an autozero. Once physically installed in a product, the direction of most gravity/down is usually a combination of X, Y, Z, very low numbers of the two off axis, but measurable, hence software calibration (zeroing) on completed units.
  10. MegaMan
    Sep 25, 2009
    53
    i don't completely understand.
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    I mostly talked about the software calibration of the accelerometer.
    You don't need a compass unless you want to know the device's direction relative to the north magnetic pole.
    The accelerometer will tell you if an item is accelerating, but not moving steadily. It gets a little complicated to determine distance moved with only an Inertial Navigation System (INS), which is what it sounds like you are attempting to create.
