Most popular and best schmitter trigger design for comparator
Discussion in 'General Electronics Chat' started by nepdeep, Dec 17, 2012.
  1. nepdeep
    Sep 14, 2011
    139
    Hi I have the following as the one I have been using...is there other good ideas or better practices...likey may be pulled to different voltage or dirrerent way of providing reference voltage...and yes easy to calculate.. schimit (Copy).jpg
  2. #12
    Nov 30, 2010
    16,705
    7,355
    The traditional Schmidt Trigger toggles at 1/3 and 2/3 Vcc and that gives it much better noise immunity than the circuit you presented. I cast a wary eye on your circuit because it might false trigger a lot more than the traditional style.
  3. atferrari
    Jan 6, 2004
    2,672
    785
    Used the one shown here.
    Seems simpler than yours because common transistors could work.
  4. crutschow
    Mar 14, 2008
    13,509
    3,385
    Depends on the accuracy you need for the trigger point.
