Thanks . I already searched there , but what I need is some suggestion from experienced LED users .Welcome to AAC!
Members here who are not in India are unlikely to know what would be 'easily available' to you in India. Can you source things by mail order from any of the major suppliers, such as Digikey, Element14, Mouser etc? If so, do a parameter search on their web-sites.
wrong websitePlease suggest a good red wine to go with an Angus beef tenderloin.
not again... making fun by trolling me ? I came here for help .not to get offended by racists. If you can't help then why don't keep your a***s off this thread ?Which tyres will be better for my ford Anglia?
Thank you very much . this is very helpful and fast answerHere is the link.
https://dannyelectronics.wordpress.com/2016/05/24/repurposing-smps-modules-as-led-drivers/
The current is programmed with an external resistor in serial with the LEDs. Up to 3amp, 36 volt - there is a higher voltage version too.
You aren't limited to that particular module. Stuff like that are readily available as long as you are willing to experiment.
Bardolino. No contest.Please suggest a good red wine to go with an Angus beef tenderloin.
Eh? The first paragraph on the first datasheet that Google found says :-there is no data about maximum output voltage from PT4115 in datasheets .
"The PT4115 is a continuous conduction mode inductive
step-down converter, designed for driving single or
multiple series connected LED efficiently from a
voltage source higher than the total LED chain voltage.
The device operates from an input supply between 6V
and 30V and provides an externally adjustable output
current of up to 1.2A."
"There is no data about maximum output voltage from PT4115 in datasheets ."
That's very difficult to believe.
by Aaron Carman
by Aaron Carman
by Duane Benson
