Most basic square wave generator needed
apurvmj
Joined Sep 28, 2012
16
Hi all,
Pls, I need most basic square wave generator, without using ICs, OP-AMPs or 555 timers. I wanted the component of these ICs or OP-AMPs which is actually responsible for generation of square wave or completely different yet most basic circuit.
I want to make 100 Hz square wave generator.
Thanks in advance.
Ramussons
Joined May 3, 2013
1,414
Hi all,
Thanks in advance.
1. Wire up a Bistable with 2 Transistors. Feed it with signal from
a) Astable made of 2 Transistors
OR
b) Pulse Generator using a UJT.
ps. An Astable can be better designed.
I don't think anything can be more basic than this.
Ramesh
sirch2
Joined Jan 21, 2013
1,037
<edit>Ramussons beat me to it</edit>
Why? and how accurate do you want the 100Hz to be?
A Bistable flip-flop driven by a simple tranisitor capacitive discharge timer may do it.
