Mosfets in Simple 4 FET H Bridge
Discussion in 'The Projects Forum' started by kashif22041, Sep 18, 2009.
  1. kashif22041
    Sep 18, 2009
    Hello
    I want to build an H bridge to control a servo motor as an DC motor and want to use MOSFETS.
    But i m not sure what are the MOSFET no's to be used. My motor is a 12v motor.
    PLease also tell if the no. u r stating is for PMOS or for NMOS.
    Thanks for ur time.:):):)
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    How much current does your motor require?
  3. JDT
    Feb 12, 2009
    658
    85
    Instead of building one out of separate transistors, have you thought of using a fully integrated device like the LMD18200? It's got controlling logic and current sensing built in as well.
    See:- http://www.national.com/ds/LM/LMD18200.pdf
    It is specified to work at 12V.
