I have generated two signals using fpga and want to drive MOSFET switches using these signals such that the output generated is a single signal with the first signal having voltage level +10V and the second signal -10V.
I have attached the picture of the signals and the circuit I have designed. As I have never used MOSFETs before in any circuits, I want you guys to help me with this. Please tell me whether the way NMOS and PMOS have been connected is right or not and also, how should their gates be driven (Should I use a high side and low side driver and give the fpga outputs to them and which one would guys suggest)?
