Mosfet
Discussion in 'Homework Help' started by Mani-chan, Jun 19, 2014.
  1. Mani-chan
    Jun 19, 2014
    How can the Q-point in a MOSFET can be stabilized against variations in transistor parameters?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    We can use negative feedback that will stabilizes the Q-poin
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    For example a resistor from source to ground in a common-source amplifier will provide negative feedback and help stabilize the bias point. If you don't want the resistor to reduce the AC gain, then you can add a bypass capacitor across the resistor.
