Did you look at post #69? I'm not sure where the negative numbers you guys keep referring to are coming from, but no negative power supplies are needed.
A 19V power supply is bit of a high starting voltage for a 555 or CMOS 555. It can be done, but it is not necessarily the best way. Using a 555 started out as a learning too.
Fact is, there are lots of chips that can do this more or less off the shelf. You could also use comparators I suspect.
Quick side note about MOSFETs in general. They take a large surge of current (duration should be as short as possible) to switch, but after the surge almost no current (less than nanoamps) to maintain. Imagine the gate is a capacitor measuring several nanofarads between gate and source. The quicker they switch, the less heat generated during the switching duration. This is why you see beefy switching circuits feeding the gate, even though the power used is extremely small. You are trying to force the gate capacitance to change voltage as quick as possible.
I can show you a hypothetical SMPS drawing if you want. We now have voltage specs, what are the current specs?
