mosfet
Discussion in 'General Electronics Chat' started by vultac, Aug 5, 2010.
  1. vultac
    Thread Starter Active Member
    Mar 2, 2009
    142
    Hi guys i need help understanding mosfets. Basically, i have the circuit as shown. Its a buck converting with a 555timer (to drive the mosfet) attached. What i dont understand is that what resistance (r77) will i need so that the mosfet wont be always on....actually i dont really understand what the resistance there does...
    Thanks in advance cheers.
  2. kingdano
    Member
    Apr 14, 2010
    377
    19
    R77 is pulling the output of the inverter up
    the MOSFET should be turning on and off at the switching frequency of the inverter.
    i assume that te Fs=50kHz is the pulse frequency of the signal controlling the FET gate.
  3. Ghar
    Mar 8, 2010
    655
    72
    That gate drive won't work very well.
    To turn an NMOS on you need to apply a Vgs, gate-to-source voltage. You're applying a gate voltage, the source voltage is a node that has a varying voltage.
  4. kingdano
    Member
    Apr 14, 2010
    377
    19
    yea, i didnt really get how that circuit was going to work.
  5. Ghar
    Mar 8, 2010
    655
    72
    The scheme would work with a PMOS however... then the pull up resistor might make sense if that logic gate was open-collector which it isn't.
  6. kingdano
    Member
    Apr 14, 2010
    377
    19
    why not just use an opamp with +/-15V rails to provide enough voltage to drive the gate?
    it really is a confusing looking thing.
    i think the idea is that the inverter only has to pull the gate to ground, and since it is common emitter (i think?) it should be able to pull low fairly well.
    i still dont think pulling a 7404's output up to 30V is a wise idea.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    The old fashioned 7404 output high is only 3.5V but the Mosfet gate needs 10V.
    Your circuit does not have a supply voltage shown but if it is higher than about 7V then R77 will not turn on the Mosfet properly and will cause the output of the old 7404 to be damaged.
  8. kingdano
    Member
    Apr 14, 2010
    377
    19
    to the OPs question about R77's value to ensure the FET turning off, try a high value resistance (10k-100k range) and see if that helps, right now you are pulling a lot of current through that 300Ω resistor which will make it next to impossible for the 7407 to sink all of it when it tries to drive low.
    unfortunately, this may not work at all, because when limiting to 5-10 mA for the 7404s sake, you may not have enough bias current to open the gate of the FET.
    some quick math and datasheet investigation should tell you if this will work reliably or not.
  9. Ghar
    Mar 8, 2010
    655
    72
    The problem with using an NMOS on the high side is that Vgs must be a large positive voltage and by definition the drain is at a slightly higher voltage than the source.
    Since the drain is your power supply, the NMOS gate must be driven above the source.
    People do this with bootstrapping (generating a voltage above supply) or isolated gate drivers (referencing gate voltage to the source regardless of what it is).
    A ground referenced driver like this just won't cut it for an NMOS.
    For a PMOS you just need the gate voltage lower than the source (connected to the supply voltage) which is easily done by a pull down network.
  10. kingdano
    Member
    Apr 14, 2010
    377
    19
    i am trying to digest all of that, my level of understanding of FET/BJT devices with PNP/NPN high/low side drivers is not really as thorough as id like.
    hopefully some of this is covered in the art of electronics.
    thanks for that explanation though.
    i didnt notice that in fact, while the source is grounded when the FET is off, when the FET is on it is going to be the voltage output.
    so there will be no differential when the FET is conducting and therefore it really just wont work.
    sorry, that may have been me "thinking outlloud" in a post.
  11. Ghar
    Mar 8, 2010
    655
    72
    You have it slightly backwards.
    When the FET is on the source should be the input voltage, it's supposed to be an ideal switch. The inductor holds the voltage difference between input and output, getting charged up.
    The thing will still switch but it won't be very good at all. The source voltage is a negative diode drop while the FET is off and then as the FET tries to turn on that voltage will quickly rise as the diode turns off.
    If you drive the gate higher than the supply (drain) voltage, then when the source rises to roughly the supply voltage you still have a positive Vgs.
  12. Ghar
    Mar 8, 2010
    655
    72
    Here are some shots from a simulation.
    I'm simply driving the gate with a ground referenced voltage source.
    The plots are drain, source, gate, and gate-source voltages.
    Input voltage is 30V.
    When the gate is driven at 10V, the standard "well driven" number (the actual voltage threshold is closer to 3V) we get this:
    Nothing good really happens. The transistor cannot turn on fully, because Vd = 30V and Vg = 10V.
    For the transistor to be on at all, Vgs > Vth, or Vg > Vs + Vth. Because the transistor does get turned on, you force Vs = 10 - 3 = 7. That gives you Vds = 23V, indicating that it's obviously in the high resistance region.
    An NMOS cannot "pull higher than gate minus threshold". That idea is commonly applied in digital circuits.
    If we drive it with Vin, 30V, you get this:
    Again the source is only pulled up to Vg - Vth, or 27V. You have Vg = Vd or Vds = Vth, which again isn't exactly low resistance. Remember a MOSFET is in the triode (on) region when Vgs > Vds + Vth, or Vg > Vd + Vth
    Now I drive it with 40V, which is Vin + 10V:
    Notice that now the source gets pulled all the way up to Vin (30V) and the gate source voltage actually becomes 10V.
  13. kingdano
    Member
    Apr 14, 2010
    377
    19
    :D
    thanks
  14. kingdano
    Member
    Apr 14, 2010
    377
    19
    and i graduated cum laude from an ABET accredited EE program.
    go education system!
  15. Ghar
    Mar 8, 2010
    655
    72
    That's how it goes I guess. School just doesn't teach everything... it gives you tools and fundamentals so you can move on with your learning.
    This simple fact was barely mentioned in my two undergrad power electronics courses and it was mentioned briefly in the transistor level digital electronics course as one of the benefits of CMOS.
    You'll always need to piece things together no matter how much you study :)
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
  17. vultac
    Mar 2, 2009
    142
    omg thanks for all the reply...... but er... IM LOST :(!!so basically, will this circuit work? Any suggestions what i can do to turn on the mosfet?
  18. vultac
    Mar 2, 2009
    142
    ok let me show u the whole circuit that i have made... together with the 555 timer, and im building on a current mirror that i dont understand how it can vary the duty cycle... basically the main objective is for me to be able to adjust the voltage from the "current mirror circuit" which i have not designed....
  19. vultac
    Mar 2, 2009
    142
    sorry note that im usign IRFz44 instead of 150..
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    This will not work. TTL is a 5V logic, and a one in TTL is around 3.5V. You need at least 10V on the gate. I suspect you haven't tried all the links people have given you. A MOSFET requires 10V on the gate to turn fully on.
    Transistor Drivers
    To understand electronics you have to read, there are no shortcuts.
