Mosfet
Discussion in 'Homework Help' started by qwerty321, Dec 17, 2009.
  1. qwerty321
    Oct 22, 2008
    14
    Hello I need help
    This is not a homework but a training exercice and I need to know how to solve it please
    In the figure, VIN is very small and we hve to find the minimum VG such that the circuits attenuates VIN by more than 5%.
    We have the values for k'(W/L), RL and Vt..
    can you help me?at least a hint
    thank you
  2. MasterSnow
    Member
    Jan 18, 2009
    22
    For small enough signals, that MOSFET's vds and Id characteristic is close to linear. This means that you've effectively got a resistor who's resistance is controlled by Vg - Vs. If you can derive or find a small signal equation that relates vds to Id linearly (and depends on Vg - Vs of course), then you can solve this like a voltage divider. It may get a little complicated though, since Vs depends on the output and therefore kind of provides feedback to your "resistor". It would have been easier if the MOSFET had been grounded instead. ;P
