Hi There,
I'm still figuring out MOSFETs and have a question. I have two of them on my board (schematic attached). One for a motor controller which seems to work fine. The other one is used to turn off current from the solar panel by interrupting it's ground connection.
The issue I'm seeing is that current flows from the panel (I'm simulating the panel with my bench power supply) even when the voltage to the MOSFET gate goes low (from 5V to mV's). If I connect a light bulb to that MOSFET I'm able to switch it on and off via the control pin on the MCU.
I think that because the current is going in the opposite direction with the panel, as opposed to the light bulb, that I need to connect the panel ground lead to the MOSFET source pin and the drain pin to ground.
The direction of the current flow is important with these MOSFETs right? Thanks for the help.
