Hello!! i have a samsung tv with model LE32C350.There is a blown item that i found out it is a MOSFET TRANSISTOR.On the part i can read this:
5N52U
GK1PK VW
CHN 014.
I can't find the exact part and i also don't understand its use.I found one from a local shop which is different as you can see from the picture.The 3 pictures are showing the board with one mosfet transistor and one empty slot (as i remove the blown one).The different one has those numbers :
P8NM60FP
GK0R2 V3
CHN 829
could this work and fix my problem?
i found some pdf with diagrams but i don't get it,i don't understand what all those numbers mean etc.all i can see is different in amps,vcc,ohm etc.
If you can help me can you please explain me,what are all those numbers on the part,what do they mean and what part is it?
5N52U
GK1PK VW
CHN 014.
P8NM60FP
GK0R2 V3
CHN 829
