MOSFET Thermal Pad - also a drain?
123j4ck
Joined Nov 6, 2015
7
Hi, I haven't used MOSFETs much before. Is the top (the plate with hole, labelled as thermal pad in the datasheet) connected to the drain? And if so could I connect to the drain using this instead of the drain pin? (have to squeeze it into a small space where this would be helpful, and am curious if this is an option..)
